[Qgis-developer] On the fly simplication of point layers
A Huarte
ahuarte47 at yahoo.es
Mon Jan 20 23:11:38 PST 2014
I agree, It is not possible, or very costly, detect if a point has semi transparent symbol
Maybe, new Point layers should have the simplification disabled by default
Alvaro
>________________________________
> De: Tim Sutton <lists at linfiniti.com>
>Para: Mathieu Pellerin <nirvn.asia at gmail.com>
>CC: QGIS Developer <qgis-developer at lists.osgeo.org>; A Huarte <ahuarte47 at yahoo.es>
>Enviado: Martes 21 de enero de 2014 6:01
>Asunto: Re: [Qgis-developer] On the fly simplication of point layers
>Hi
>Sent from my mobile
>On 21 Jan 2014 3:10 AM, "Mathieu Pellerin" <nirvn.asia at gmail.com> wrote:
>> Also, that logic can only be applied for fully opaque point symbols. As soon as you have a semi transparent symbol, the repetition of points over a same map pixel does matter and needs to be preserved.
>Agreed but in that case surely you would just disable simplification?
>Regards
>Tim
>> On 21 Jan 2014 07:46, "A Huarte" <ahuarte47 at yahoo.es> wrote:
>>> Ok, I will study it
>>>> If you have time and inclination this would be great (note feature freeze starts in 4 days). A logical starting may be to only return one point per map pixel though I am not sure if you can push that kind of logic over to provider side very easily.
>>>> Regards
>>>> Tim
>>>>>> Para: A Huarte <ahuarte47 at yahoo.es>
>>>>>> CC: qgis-developer <qgis-developer at lists.osgeo.org>
>>>>>> Enviado: Lunes 20 de enero de 2014 22:57
>>>>>> Hi
>>>>>> On Mon, Jan 20, 2014 at 11:47 PM, A Huarte <ahuarte47 at yahoo.es> wrote:
>>>>>>> done:
>>>>>>> https://github.com/qgis/QGIS/pull/1093
>>>>>>> This patch hides the simplification rendering tab for point layers, now it is not supported (internally I am not trying to simplify point layers). Thanks Tim!
>>>>>>> About if there is a use case for point simplification, I know one, (gvSIG + dielmo open lidar) use it for load extreme big point layers as LiDAR LAS files are.
>>>>>>> It know the code in java and I think easy migrate to QGIS. Basically, It ignore points by distance in a similar style as the current simplifier classes.
>>>>>> Sorry I see my original email was not very clear - I meant if there was a use case for point simplification as *currently implemented in master* - I fully agree that filtering proximal points would be a good performance booster, as would providing a point clustering capability.
>>>>>>> If you think good for QGIS I think but I can imlement it
>>>>>> That would be great! Thanks for your pull request.
>>>>>> Regards
>>>>>> Tim
>>>>>>> Alvaro
>>>>>>>> Para: qgis-developer <qgis-developer at lists.osgeo.org>
>>>>>>>> Enviado: Lunes 20 de enero de 2014 21:29
>>>>>>>> Asunto: [Qgis-developer] On the fly simplication of point layers
>>>>>>>> Ok I guess you can see where I am going to go with this email :-) Is there any point to allowing users to simplify point layers? Alvaro, can your remove the point rendering tab in layer properties (and I guess check internally that you are not trying to simplify point layers)? Or is there a use case for point simplification that I am not getting?
>>>>>>>> Regards
>>>>>>>> Tim
>>>>>>>> Tim Sutton - QGIS Project Steering Committee Member
>>>>>>>> Please do not email me off-list with technical
>>>>>>>> support questions. Using the lists will gain
>>>>>>>> more exposure for your issues and the knowledge
>>>>>>>> surrounding your issue will be shared with all.
>>>>>>>> Irc: timlinux on #qgis at freenode.net
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-developer mailing list
>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140121/1d3a7920/attachment.html>
