[Qgis-developer] Can we deactivate the Select datum transformations dialog by default?
Matthias Kuhn matthias.kuhn at gmx.ch
Mon Jan 20 23:31:50 PST 2014
The main problem for me is the modal popup which breaks the workflow
and it's not easy to grasp the meaning the first time you see it.
Alternatives:
Message bar:
"Default transformation settings have been chosen for layers 'Moon' and
'Mars'. If you would like to change the settings please click here. For
more information click here."
Or in the TOC there could be a small exclamation mark next to affected
layers, and the mouseover could give a hint about "unconfirmed
transformation" and how to solve it. This would be even less intrusive.
Matthias
On Tue 21 Jan 2014 08:24:04 AM CET, Marco Hugentobler wrote:
> Hi
> I can live with either showing / not showing by default.
> Just note that without showing, many people are receiving wrong
> transformation results without any hint. In my opinion, a normal GIS
> user should never have to do otf-reprojection, it is far to error
> prone (better, let the surveying departement do the conversion between
> different systems).
> Regards,
> Marco
> On 21.01.2014 07:36, Paolo Cavallini wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Il 21/01/2014 01:10, Mathieu Pellerin ha scritto:
>>> +1, for two reasons:
>>> * the advances function isn't needed for many types of qgis users
>>> * the UI would benefit from re arrangements to make it more friendly
>>> when users run
>>> into it (ie a short paragraph above list box to explain what this is
>>> about, like with
>>> the crs selector)
>> I also find the current setting quite intimidating for many, probably
>> most, users.
>> Should we open a ticket?
>> All the best.
>> - -- Paolo Cavallini - www.faunalia.eu
>> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1
>> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
>> iEYEARECAAYFAlLeFVEACgkQ/NedwLUzIr4EowCeNXPxPRsP7BdU2E2GJcwFRAEx
>> QvYAmwXP+8mhZWXzi5gl6wh23wLvPxyv
>> =4Vkj
>> -----END PGP SIGNATURE-----
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
