[Qgis-developer] QGis Dufour crashes when using QgsMarkerLineSymbolLayerV2.setSubSymbol()
alain
al.bertho at free.fr
Thu Jan 23 10:15:17 PST 2014
Hello,
QgsSVGFillSymbolLayer.setSubSymbol() (to put the outline symbol of a
polygon) also makes crash QGis.
I tested this with linux and windows 7.
I've found a workaround with QgsMarkerLineSymbolLayer.createFromSld().
This does work from within a python plugin.
QgsMarkerLineSymbolLayer.createFromSld() call setSubSymbol method from
the C++ part. So maybe the problem comes from the python bindings, but I
don't know sip.
Shall I report this as a bug?
Alain
Le 20/01/2014 22:31, alain a écrit :
> Hello,
> I'm working on a python plugin to render S57 nautical charts using the
> ogr provider and QGis symbology. For now, I'm just testing how to use
> Symbology, as I'm not familiar with it, so I think I do something
> wrong, but can't find examples on Google.
> I need to compose symbols for lines, using Svg files. This seems to be
> done using one or more QgsSvgMarkerSymbolLayerV2 in a QgsMarkerSymbol
> wrapped in a QgsMarkerLineSymbolLayerV2 using setSubSymbol(...)
> method. Following this idea, I get QGis crashes.
> I post some code at
> http://gis.stackexchange.com/questions/83517/qgis-dufour-crashes-when-using-qgsmarkerlinesymbollayer-from-a-python-plugin
> When I comment the line calling setSubSymbol(), the layer is rendered
> correctly with a default symbol.
> Thanks for help.
> Alain
> Qgis-developer mailing list
