[Qgis-developer] On the fly simplication of point layers
Tim Sutton lists at linfiniti.com
Thu Jan 23 14:16:06 PST 2014
Hi
On Wed, Jan 22, 2014 at 2:47 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Wed, Jan 22, 2014 at 1:23 PM, Martin Dobias <wonder.sk at gmail.com>wrote:
>> On Wed, Jan 22, 2014 at 4:33 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> >> Actually the point displacement renderer already does clustering,
>> >> though it lacks more options to customize how the clustered symbol
>> >> would look like.
>> > Doesnt it do the reverse? i.e. when more than one point falls in the
>> same
>> > place, it shifts them aside so they are all visible. If it can be made
>> to
>> > produce a scaled symbol based on the number of underlying points that
>> would
>> > be cool.That would also be a good time to change its name to 'Custer or
>> > displace' or something.
>> I think that was what the renderer did originally, but nowadays it
>> also groups points within configured distance. Unfortunately it always
>> tries to draw a circle around the clustered point with original
>> symbols. If we introduced few rendering options, it would be more
>> useful:
>> - draw just the clustered symbol for the whole group
>> - scale the clustered symbol depending on the number of points inside
> Yeah that should do it!
I tested with a large point dataset (geonames ~3.5 million records).
Basically enabling the point displacement renderer on that layer kills (or
takes so long I killed it) QGIS. Since the essence of clustering is to
speed up rendering times and reduce visual clutter, I suspect simple tweaks
to the renderer would not be enough.
Regards
Tim
> Regards
> Tim
>> Cheers
>> Martin
> Tim Sutton - QGIS Project Steering Committee Member
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140124/c49e6c16/attachment.html>
