[Qgis-developer] save as spatialite very resource consuming
Rafael Krucker
rkrucker at hsr.ch
Fri Jan 24 03:36:34 PST 2014
Hello all
I've noticed recently (QGIS 2.0.1, Windows 7 64 bit), that, when I'm
processing a shapefile as layer, even very small ones, the operation
'save as spatialite' takes forever. With a small shapefile (1 KB), the
process of converting takes up to 3 minutes, the generated spatiallite
is then always around 4000 bigger (4.21 MB). These ratios are the same,
no matter how big the file is, the time taken enlarges linearly it seems.
When the export is a shapefile again, the whole thing is a matter of
seconds.
Is this due to some kind of buffering issues or does this conversetion
simply take that many resources?
Kind regards and thanks in advance for any pointers
Rafael
