[Qgis-developer] data provider in a custom app
Tim Sutton
lists at linfiniti.com
Thu Jan 23 14:12:18 PST 2014
Hi
On Thu, Jan 23, 2014 at 3:58 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
> Hi all,
> I am trying to do a custom application using QGIS libs and I have trouble
> to use data providers (i.e. spatialite).
> In my application doing, QgsProviderRegistry::instance()->pluginList()
> returns " No data provider plugins are available. No vector layers can be
> loaded".
> Then of course, trying to create a new db as it is done on
> QgsNewSpatialiteLayerDialog is impossible (
> QgsProviderRegistry::instance()->library( "spatialite" ); )
> and loading layers with
> QgsVectorLayer* vl = new QgsVectorLayer( "dbname='path_to_sqlite_file'
> table='mytable'' (geometry) sql=", "layername", "spatialite" );
> fails.
> I believe I am missing something fundamental here, but I have no idea what.
> If anybody has a lead, thanks a lot.
Did you ensure the QGIS_PREFIX_PATH is set and call initQgis? See [1] for
an example.
[1] https://github.com/AIFDR/inasafe/blob/master/safe/common/testing.py#L692
Regards
Tim
> Cheers,
> Denis
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140124/9a153d78/attachment.html>
