[Qgis-developer] New composer's title
Andreas Neumann
a.neumann at carto.net
Sat Jan 25 01:54:46 PST 2014
+1 for removing it. Maybe an auto-generated name that does not clash
with existing composer names would be useful - which the user can later
on rename.
The user will have to set paper format anyway. In this step he can also
set the composer name.
Andreas
Am 25.01.2014 09:04, schrieb kimaidou:
> Hi Martin
> +1 for removing it, as it is a step I usually skip too. But only if we
> provide a input field in the composer properties tab to allow to add/change
> the name directly in the opened composer (above the paper size for
> example). This way I won't need to open the composer manager only to rename
> it afterwards.
> Michael
> 2014/1/25 Martin Dobias <wonder.sk at gmail.com>
>> Hi
>> Is there any good reason for the small pop-up dialog asking for
>> composer name when user wants to create a new composer? There is the
>> composer manager where the composer can be renamed at any time, so to
>> me it looks like an unnecessary step and I would be happy to remove it
>> Regards
>> Martin
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
