[Qgis-developer] About "temp" directory
Minoru Akagi
akaginch at gmail.com
Sat Jan 25 18:05:32 PST 2014
Hi Roberto,
> you asked me if I had some reason to define my GEarthView "temp"
> directory inside the plugin.
> Well, now I found the reason
ok, thanks. In case of processing plugin, by default, temporary
outputs are put into a directory that QDir.tempPath() returns [1].
Qgis2threejs is following it (Processing has an option to change
temporary output directory).
Regards,
Minoru
[1] https://github.com/qgis/QGIS/blob/master/python/plugins/processing/tools/system.py#L55
2014-01-26 Geo DrinX <geodrinx at gmail.com>:
> Hi Minoru,
> Well, now I found the reason: where is the "temp" of QGis2threejs, in
> MacOSX ?
> I can not find it … Also because you change HTML name :)
> Ciao
> Roberto
