[Qgis-developer] About "temp" directory
Minoru Akagi
akaginch at gmail.com
Sat Jan 25 18:23:41 PST 2014
> (Processing has an option to change
> temporary output directory).
I'm sorry. This was not correct. The option is not for temporary files
but for filename without path [1].
[1] http://lists.osgeo.org/pipermail/qgis-user/2013-November/024855.html
Minoru
2014-01-26 Minoru Akagi <akaginch at gmail.com>:
> Hi Roberto,
>> you asked me if I had some reason to define my GEarthView "temp"
>> directory inside the plugin.
>> Well, now I found the reason
> ok, thanks. In case of processing plugin, by default, temporary
> outputs are put into a directory that QDir.tempPath() returns [1].
> Qgis2threejs is following it (Processing has an option to change
> Regards,
> Minoru
> [1] https://github.com/qgis/QGIS/blob/master/python/plugins/processing/tools/system.py#L55
> 2014-01-26 Geo DrinX <geodrinx at gmail.com>:
>> Hi Minoru,
>> Well, now I found the reason: where is the "temp" of QGis2threejs, in
>> MacOSX ?
>> I can not find it … Also because you change HTML name :)
>> Ciao
>> Roberto
