[Qgis-developer] Cad-Input for QGIS prototype
Olivier Dalang
olivier.dalang at gmail.com
Wed Jan 29 03:39:32 PST 2014
Hi !
Ok the plugin is published in the repo (with a nice icon for the occasion
;) ) ! Champagne !
*@Denis*
I wanted to say that if you need a hand on implementing things in the API,
> I can help. Although I am by far not the most advanced programmer around, I
> am truly interested by your development. And I'm somehow in charge of the
> map tools ;)
*Help on the API is more than welcome ! (I'm too much of a newbie in C++ to
do any serious work).*
*I'd say the C and D improvements suggested in the readme are the easiest
and could be a good point to start.*
*The E improvement (an UI improvement rather than API improvement) would be
welcome also (and be appreciated beyond the scope of this plugin).*
*I'm not sure if the A use useful, but it should be easy to implement and
may be useful to other plugins.*
*B would probably require more work (refactoring every single map tool,
unless we integrate the snapping hack as a default implementation, which I
think is a very bad idea).*
*I'd say before doing something like this, it could be a nice idea to think
about the point I made in my last post about a more rigid base class for
mapTools.*
Do you have a build environment? If so, while in the feature freeze period,
> we could work on a different branch.
*Yes, so testing another branch is no problem.*
By the way, was that a paid development or personal initiative?
*It is a personal initiative (i'm of course open to post-work sponsoring ;)
Cheers,
Olivier
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140129/a6080a83/attachment.html>
