[Qgis-developer] point displacement style
Andreas Neumann
a.neumann at carto.net
Fri Jan 31 00:38:19 PST 2014
Hi Luca,
I can't help with the labeling. At the time the point displacement
renderer was developed (about 5 years ago), the labeling engine wasn't
as advanced as it is today. So it wasn't an option and also not
necessary to the project.
I would not regard this as a bug request, but as a feature request and I
guess it would a substantial bit of work to integrate the new labeling
engine with the point displacement renderer.
Do you have an idea how it should behave? I guess, depending on how many
points there are there isn't a solution to perfectly label all points.
The point displacement renderer could also be improved to display points
in a cluster, not just around the circle, but also inside the circle.
This would be more complex to implement, but it would save map/screen
space and would visually more pleasing.
If you have funds available - please consider hiring a developer.
Regarding the second issue: this may be a bug. Or in extreme cases - if
you have many points at a single location - the circle could be so big
that it is rendered outside of the visible rendered map area.
I am also a user of the point-displacement renderer - so I would like to
see improvments in this feature!
Thank you for bringing this up.
Andreas
Am 31.01.2014 09:14, schrieb Luca Lanteri:
> Hi to all,
> I'm using the point diplacement style. I noticed that it doesn't use the
> new label engine for labelling the diplaced simbol, so the collision engine
> doesnt' work.
> There's in plain to migrate it to the new label engine? It could be useful
> if I open a ticket ?
> I also have some visualization problem, because at some scale the point
> displaced symbols disappear (tested on qgis 2.10 Master - Ubuntu
> 13.04-64bit). Anyone can confirm this problem ?
> Thanks in advance
> Luca
> Qgis-developer mailing list
