[Qgis-developer] Do we need a single select map tool?
Giuseppe Sucameli
brush.tyler at gmail.com
Wed Jul 2 08:04:40 PDT 2014
On Wed, Jul 2, 2014 at 2:50 PM, Ramon Andiñach <custard at westnet.com.au>
wrote:
> If the default was changed to rectangle, I'd expect that most would change
> it the first time that they needed to do a single point select anyway.
And if they try to change back to the single point selection but the tool
is missing, what do you think they will do?
I'm quite sure that after 20 seconds they will use the rectangle selection
tool to click on the map.
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140702/5c6f511b/attachment-0001.html>
