[Qgis-developer] error creating QGIS package with creatensis
Jürgen E. Fischer jef at norbit.de
Thu Jul 3 01:46:18 PDT 2014
Hi Matteo,
On Thu, 03. Jul 2014 at 10:11:42 +0200, matteo wrote:
> I've checked the setup.ini in the packages-x86_64 directory and the
> gdal-sosi version is the old one:
> @ gdal-sosi
> sdesc: "OGR SOSI Driver"
> ldesc: "The OGR SOSI Driver enables OGR to read data in Norwegian SOSI
> standard (.sos)"
> category: Libs
> requires: gdal msvcrt
> version: 4.0-1
> install: x86_64/release/gdal/gdal-sosi/gdal-sosi-4.0-1.tar.bz2 107731 5f6369cecb42d857e3251d3ace3cb4bc
> [prev]
> version: 4.0-1
That's not the current one.
http://download.osgeo.org/osgeo4w/x86_64/setup.ini has:
@ gdal-sosi
ldesc: "The OGR SOSI Driver enables OGR to read data in Norwegian SOSI standard (.sos)"
category: Libs
version: 4.0-2
install: x86_64/release/gdal/gdal-sosi/gdal-sosi-4.0-2.tar.bz2 107739 280d83a1355296cbbcd621dfd43ef4b3
[prev]
version: 4.0-1
Did you remove the old setup.ini from packages-x86_64?  Did the old one get
refetched?  Are you behind a (caching) proxy?
> I've updated the repo right now but nothing changed.
> As a temporary workaround, can I delete the gdal-sosi lines from the
> setup.ini? This way the package should be successfully created without
> sosi right?
It probably will still include it - as qgis-full points to it and the packages
is already there.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
