[Qgis-developer] error creating QGIS package with creatensis
matteo matteo.ghetta at gmail.com
Thu Jul 3 02:18:46 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Jürgen,
> That's not the current one.
mmm, I see...
> http://download.osgeo.org/osgeo4w/x86_64/setup.ini has:
> @ gdal-sosi sdesc: "OGR SOSI Driver" ldesc: "The OGR SOSI Driver
> enables OGR to read data in Norwegian SOSI standard (.sos)"
> category: Libs requires: gdal msvcrt version: 4.0-2 install:
> x86_64/release/gdal/gdal-sosi/gdal-sosi-4.0-2.tar.bz2 107739
> 280d83a1355296cbbcd621dfd43ef4b3 [prev] version: 4.0-1 install:
> x86_64/release/gdal/gdal-sosi/gdal-sosi-4.0-1.tar.bz2 107731
> 5f6369cecb42d857e3251d3ace3cb4bc
> Did you remove the old setup.ini from packages-x86_64?  Did the old
> one get refetched?
Now I've removed it and re-launced creatensis.. It seems working!
Are you behind a (caching) proxy?
No proxy here
> It probably will still include it - as qgis-full points to it and
> the packages is already there.
Just for info: in the meanwhile I've tried to launch creatensis after
having removed the sosi lines from setup.ini.
Package has been created (for now I cannot test if the package works
because I'm not on a 64bit machine).
Thanks!
Matteo
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iQEcBAEBAgAGBQJTtR/2AAoJEBy7UYf0gaEOX8gH/ib9Y5Q+tH82yzHjCBsomTQw
QUc3ZAE+A0ysiZmIngR6MpoPZlHmzieawypNxo6xE4a9qUGIRJkz447Dsiw1S2Hk
ZIXUG3DahxA9gQfsncCuTckFJqiPYzRJN8mc/mQEi0YiG2zy1kvonObrI1G3RpWz
myRDROt2dNej8AdJATDj9MvIFou7bijyLtc0BeGZg1K3GJKgkr4ugY0IYP9Xqrxw
0oeAMMAf7Wl4cB5dZNZ32302f/1ayjBcFa/jRiz/9lpXIS24GeJ85GS9S9zWKVok
OVfvraFek0dM3C2W38Tcf7+9gVgydRapvFf9KnEc+ucjTvpEM5m85IICk7DG87Y=
=y8AH
-----END PGP SIGNATURE-----
