[Qgis-developer] slow loading projects (with layouts) and crashes when "renders layers in parallel using many CPS cores" is ON
Giovanni Manghi giovanni.manghi at faunalia.pt
Wed Jul 9 09:13:01 PDT 2014
Hi all,
there are reports in the bug tracker about two situations in qgis 2.4.
I would like to know if anyone else confirms:
* it seems that adding print layouts make loading of projects more and
more slow, this was not the case in 2.2
http://hub.qgis.org/issues/10828#note-17
* qgis 2.4 seems that can become unstable if "renders layers in
parallel using many CPS cores" is ON and/or the number of cores used
is high
http://hub.qgis.org/issues/10778#note-13
http://hub.qgis.org/issues/10744#note-6
cheers
-- G --
