[Qgis-developer] Compiling QGIS and C++ Application with QGIS Headers on Windows 8.1
Nathan Woodrow
madmanwoo at gmail.com
Fri Jul 11 06:40:49 PDT 2014
Hey Joshua,
If your plan is to build a small application using QGIS I would recommend
using Python with PyQGIS. It's very easy to get up and running with that
and your dev time will be much faster. Plus you don't have to compile it
for every platform under the sun ;)
If you are keen to try that I have a working Python PyQGIS app here:
https://github.com/DMS-Aus/Roam which include code to create a standalone
exe with everything included. That is pretty full on example but I can
strip it down to the most important parts if needed.
Regards,
Nathan
On Fri, Jul 11, 2014 at 11:29 PM, Joshua Quesenberry <engnfrc at gmail.com>
wrote:
> Good Morning,
> I tried painfully to get QGIS compiled last night, but I’ve had no such
> luck. I’d like to try adding some features to the program in the future,
> but I’d also like to be able to build my own C++ applications that have
> access to the interface and can display basic map data.
> I’m trying to follow the instructions on the INSTALL page (
> http://htmlpreview.github.io/?http://github.com/qgis/QGIS/blob/master/doc/INSTALL.html
> My current setup is this:
> Windows 8.1
> Visual Studio Express 2013
> QGIS was standalone installed a month or so ago and is version 2.2.0
> QT 5.3
> CMake
> Git (I’m using the main download at http://msysgit.github.io/ along with
> TortoiseGit)
> Flex
> Bison
> OSGeo4W Advanced Installation with all the required packages
> I tried Installing the Windows SDK for Windows 7 and .NET Framework 4, but
> after an hour of installing it was no more than like 1% complete, so I
> assume it was broken. Maybe I need the Windows SDK for Windows 8.1 and .NET
> Framework 4.5.1?
> Can you all help me get squared away? I was installing recent version of
> software, but maybe I need the very specific versions that are mentioned
> (Visual Studio Express 2010, QT 4.x, Windows 7)?
> Just as some background with where I want to go with all of this; for one
> I’m working on a small project in Visual Studio Express that allows me to
> analyze the game Scotland Yard, for two I’ve been involved with Search and
> Rescue for a little over a decade and we have some tools that are being
> developed alongside ArcGIS that over an unknown period of time I’d like to
> try to make available through freely available software.
> Thanks!
> Josh Q
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140711/c23e2228/attachment.html>
