[Qgis-developer] Compiling QGIS and C++ Application with QGIS Headers on Windows 8.1
Denis Rouzaud
denis.rouzaud at gmail.com
Sat Jul 12 08:44:58 PDT 2014
I have successfully built a qgis app.
You can find a summary in this post
http://3nids.wordpress.com/2014/02/27/build-and-deploy-c-qgis-app-on-windows/
I hope you can get a few leads from it.
Cheers,
Denis
Le samedi 12 juillet 2014, Joshua Quesenberry <engnfrc at gmail.com> a écrit :
> Have you all tried the QGIS Code Examples in the past few years? They don't
> work with all the code changes that have been made. Could someone update
> them so that they're actually doable?
> I'm atleast at the point now where I can start trying to build code in
> Visual Studio, which is a big improvement over where I was a few days ago.
> Getting the cmake-gui setup was painful, I had to use a combination of
> OSGeo4W64 directory, the QGIS repository, and the QGIS standalone install
> directory to get to this point. Better instructions on how to setup all of
> that on Windows would be great. I think the fact that I'm on a 64 bit
> system
> and the of stuff needed is in both Program Files and Program Files (x86) is
> breaking things. I'm also having to add a bunch of include directories to
> the actual Visual Studio project settings; I thought CMake was responsible
> for setting everything up?
> Please help make this setup process more intuitive and update the code
> examples so that they're actually usable.
> Thanks,
> Josh Q
> -----Original Message-----
> From: Joshua Quesenberry [mailto:engnfrc at gmail.com <javascript:;>]
> Sent: Friday, July 11, 2014 10:48 AM
> To: 'Jürgen E. Fischer'; qgis-developer at lists.osgeo.org <javascript:;>
> Cc: engnfrc at gmail.com <javascript:;>
> Subject: RE: [Qgis-developer] Compiling QGIS and C++ Application with QGIS
> Jürgen,
> So if I'm understanding you correctly, I'll take the following actions:
> Uninstall VS2013 and replace it with VS2010 (since I'm running
> Windows 8.1 and it's 64bit)
> Uninstall Qt 5.3 and replace it with Qt 4.x (assuming that the
> specific subversion is negligible?)
> Also, an unanswered part of this is do I need Windows SDK 7 with .NET 4? As
> mentioned, the installation was completely hung up on my Windows 8.1
> machine. I was thinking that the SDK and .NET were part of the Visual
> Studio
> Express installation, but the INSTALL page seems to imply otherwise. Do I
> instead need Windows 8.1 SDK with .NET 4.5 since I'm running Windows 8.1?
> Or
> will the Visual Studio Express 2010 installation be sufficient? If I need
> Windows SDK 7 with .NET 4 I may be in troble...
> Thanks,
> Josh Q
> From: qgis-developer-bounces at lists.osgeo.org <javascript:;>
> [mailto:qgis-developer-bounces at lists.osgeo.org <javascript:;>] On Behalf
> Of Jürgen E.
> Fischer
> Sent: Friday, July 11, 2014 9:52 AM
> To: qgis-developer at lists.osgeo.org <javascript:;>
> Subject: Re: [Qgis-developer] Compiling QGIS and C++ Application with QGIS
> Hi Joshua,
> On Fri, 11. Jul 2014 at 09:29:11 -0400, Joshua Quesenberry wrote:
> > I'm trying to follow the instructions on the INSTALL page
> > (http://htmlpreview.github.io/?http://github.com/qgis/QGIS/blob/master
> > /doc/I
> > NSTALL.html )
> > My current setup is this:
> > Windows 8.1
> > Visual Studio Express 2013
> > QGIS was standalone installed a month or so ago and is version 2.2.0
> > QT 5.3
> QGIS doesn't support Qt 5.x yet.
> If you want to use the dependencies from OSGeo4W, you'll have to use the
> tools they were build with (especially the C++ dependencies like Qt; ie.
> VC2008 on 32bit and VC2010 on 64bit).
> If you build your own Qt using VC 2013 might also be an option. But I'd
> recommend to stick to INSTALL and use the dependencies from OSGeo4W.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <javascript:;>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140712/2837697b/attachment.html>
