[Qgis-developer] Building QGIS with VS - Install Guide
SSchmidt at gfi-gis.de SSchmidt at gfi-gis.de
Thu Jul 17 00:28:41 PDT 2014
Hello,
I followed the instructions of the script and have created such a
batchfile. First I've installed bison to a path with spaces inbetween.
Thatswhy I put the path with the ~ in %PATH% and in CMAKE. Sometimes
everything going good but in some cases this error occured. So first I
deinstalled Bison and installed it to a path without spaces but created a
shortcut to startmenu. Also I changed the path-variable in batch but it
doesn't worked. Then I found this link (
http://www.chriscalender.com/?p=798 ) and this solved my problem.
But maybe its really incorrect. I'm not sure with the PATH-variable in
Win7. There is one for system and one for user and both aren't doing what
I want. So maybe path was not correctly set.
Greetings
Susann
Jürgen E. Fischer <jef at norbit.de>
Sent by: qgis-developer-bounces at lists.osgeo.org
16.07.2014 18:55
To
qgis-developer at lists.osgeo.org
cc
Subject
Re: [Qgis-developer] Building QGIS with VS - Install Guide
Moin Susann,
On Wed, 16. Jul 2014 at 17:33:41 +0200, SSchmidt at gfi-gis.de wrote:
> please add someone a hint at the INSTALL Guide
http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc14
> for building QGIS with VS that while Installing Bison no shortcut to
start
> menu had to be created. In my case this was the reason of the error:
> Generating qgsexpressionparser.cpp
> C:\GnuWin32\bin\bison.exe: m4: No such file or directory
I don't understand the references to the shortcut.  The error means you
didn't
have C:\GnuWin32\bin in PATH and therefore bison was unable to find m4.
The batch file from which you should start all other things does that (s.
"4.1.3. Setting up the Visual Studio project with CMake").
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel.
+49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
+49-4931-918175-50
Software Engineer           D-26506 Norden
http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on
FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140717/8e0ca0e2/attachment.html>
