[Qgis-developer] Geoprocessing Bug on ubuntu 14.04 and OSGEO4W
Randal Hale
rjhale at northrivergeographic.com
Sun Jul 20 10:47:23 PDT 2014
Sorry if this is cross posting (to a degree - I just filed a bug report
also).
This occurs on Ubuntugis-unstable and osgeo4w 64bit.
I've run into a problem using clip under geoprocessing: I'm clipping a
large contour dataset by a polygon. At 34% ubuntu throws an error and at
35% windows throws an error. I went back and double checked
projection/data/etc. Both windows and Ubuntu seem to create the same
log. Here is the Ubuntu-unstable one:
/An error has occured while executing Python code: /
/Traceback (most recent call last)://
//File "/usr/share/qgis/python/plugins/fTools/tools/doGeoprocessing.py",
line 316, in run//
//geos, feature, match, error = self.clip()//
line 1537, in clip//
//geom = QgsGeometry( inFeatA.geometry() )//
//TypeError: arguments did not match any overloaded call://
//QgsGeometry(): too many arguments//
//QgsGeometry(QgsGeometry): argument 1 has unexpected type 'NoneType'/
/Python version://
//2.7.6 (default, Mar 22 2014, 23:03:41) //
//[GCC 4.8.2]/
/QGIS version://
//2.4.0-Chugiak Chugiak, exported/
/Python path: ['/usr/share/qgis/python/plugins/processing',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/httplib2-0.8-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/requests-2.0.1-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/raven-3.5.1-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/gsconfig-0.6.6-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/gsimporter-0.1-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/nose-1.3.0-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/nose_html-1.1-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/coverage-3.7-py2.7-win32.egg',
'/usr/share/qgis/python', u'/home/rjhale/.qgis2/python',
u'/home/rjhale/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PILcompat',
'/usr/lib/python2.7/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.7',
'/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs',
'/home/rjhale/.qgis2/python/plugins/DigitizingTools/tools',
'/home/rjhale/.qgis2/python/plugins/MetaSearch/ext-libs',
'/usr/share/qgis/python/plugins/fTools/tools']/
I filed a bug report: http://hub.qgis.org/issues/10917
I have shared my data if you wish to play with it (337mb):
https://drive.google.com/folderview?id=0B8WLtz606XDdOTNkN0xhenVCX0k&usp=sharing
Thanks again,
Randy
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
http://www.northrivergeographic.com/spatial-connect
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140720/b049657e/attachment.html>
