[Qgis-developer] Geoprocessing Bug on ubuntu 14.04 and OSGEO4W
James Wood
jwood911 at gmail.com
Mon Jul 21 04:26:12 PDT 2014
Randy,I can confirm on Win 7 x64 with the standalone installer. It was toast at 35%... right on cue. As an alternative, in the Processing Toolbox, under SAGA>Shapes - Tools>Cut shapes layer worked super quick using the 'completely contained' method. Best Regards,James Date: Sun, 20 Jul 2014 13:47:23 -0400
To: qgis-developer at lists.osgeo.org
Subject: [Qgis-developer] Geoprocessing Bug on ubuntu 14.04 and OSGEO4W
Sorry if this is cross posting (to a degree - I just filed a bug
report also).
This occurs on Ubuntugis-unstable and osgeo4w 64bit.
I've run into a problem using clip under geoprocessing: I'm clipping
a large contour dataset by a polygon. At 34% ubuntu throws an error
and at 35% windows throws an error. I went back and double checked
projection/data/etc. Both windows and Ubuntu seem to create the same
log. Here is the Ubuntu-unstable one:
An error has occured while executing Python code:
File
"/usr/share/qgis/python/plugins/fTools/tools/doGeoprocessing.py",
line 316, in run
geos, feature, match, error = self.clip()
File
line 1537, in clip
geom = QgsGeometry( inFeatA.geometry() )
TypeError: arguments did not match any overloaded call:
QgsGeometry(): too many arguments
QgsGeometry(QgsGeometry): argument 1 has unexpected type
'NoneType'
Python version:
2.7.6 (default, Mar 22 2014, 23:03:41)
[GCC 4.8.2]
QGIS version:
2.4.0-Chugiak Chugiak, exported
Python path: ['/usr/share/qgis/python/plugins/processing',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/httplib2-0.8-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/requests-2.0.1-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/raven-3.5.1-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/gsconfig-0.6.6-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/gsimporter-0.1-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/nose-1.3.0-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/nose_html-1.1-py2.7.egg',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs/coverage-3.7-py2.7-win32.egg',
'/usr/share/qgis/python', u'/home/rjhale/.qgis2/python',
u'/home/rjhale/.qgis2/python/plugins',
'/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
'/usr/lib/python2.7/plat-x86_64-linux-gnu',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PILcompat',
'/usr/lib/python2.7/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.7',
'/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
'/home/rjhale/.qgis2/python/plugins/opengeo/ext-libs',
'/home/rjhale/.qgis2/python/plugins/DigitizingTools/tools',
'/home/rjhale/.qgis2/python/plugins/MetaSearch/ext-libs',
'/usr/share/qgis/python/plugins/fTools/tools']
I filed a bug report: http://hub.qgis.org/issues/10917
I have shared my data if you wish to play with it (337mb):
https://drive.google.com/folderview?id=0B8WLtz606XDdOTNkN0xhenVCX0k&usp=sharing
Thanks again,
Randy
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
http://www.northrivergeographic.com/spatial-connect
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140721/1673159f/attachment-0001.html>
