[Qgis-developer] Is fastest (not shortest) path routing possible in PyQGIS
Anita Graser anitagraser at gmx.at
Sun Jul 20 12:53:29 PDT 2014
Hi Giovanni,
Would it be possible to add the speed properter? Or does it make more
sense to write new properters in python if that's possible?
Thanks and best wishes,
Anita
On Thu, Jul 17, 2014 at 7:02 PM, G. Allegri <giohappy at gmail.com> wrote:
> AFAICS onli the distance properter is exposed:
> https://github.com/qgis/QGIS/tree/master/python/analysis/network
> giovanni
> Il 17/lug/2014 18:53 "Anita Graser" <anitagraser at gmx.at> ha scritto:
>> Hi,
>> The network analysis lib allows shortest path routing as documented in
>> the PyQGIS Cookbook and the API docs:
>> http://qgis.org/api/classQgsEdgeProperter.html
>> This page also lists a src/plugins/roadgraph/speedproperter.h which -
>> I assume - would enable fastest path routing. Is this class exposed to
>> Python?
>> Anita
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
