[Qgis-developer] Is fastest (not shortest) path routing possible in PyQGIS
G. Allegri giohappy at gmail.com
Sun Jul 20 15:15:19 PDT 2014
I haven't tried but you should be able to define your properter on Python
side, given that QgsArcProperter is exposed to it.
For a speed properter example you could take a look to the one implemented
within the road graph plugin:
https://github.com/qgis/QGIS/blob/master/src/plugins/roadgraph/speedproperter.cpp
giovanni
Il 20/lug/2014 21:53 "Anita Graser" <anitagraser at gmx.at> ha scritto:
> Hi Giovanni,
> Would it be possible to add the speed properter? Or does it make more
> sense to write new properters in python if that's possible?
> Thanks and best wishes,
> Anita
> On Thu, Jul 17, 2014 at 7:02 PM, G. Allegri <giohappy at gmail.com> wrote:
> > AFAICS onli the distance properter is exposed:
> > https://github.com/qgis/QGIS/tree/master/python/analysis/network
> > giovanni
> > Il 17/lug/2014 18:53 "Anita Graser" <anitagraser at gmx.at> ha scritto:
> >> Hi,
> >> The network analysis lib allows shortest path routing as documented in
> >> the PyQGIS Cookbook and the API docs:
> >> http://qgis.org/api/classQgsEdgeProperter.html
> >> This page also lists a src/plugins/roadgraph/speedproperter.h which -
> >> I assume - would enable fastest path routing. Is this class exposed to
> >> Python?
> >> Anita
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140721/7f12d347/attachment-0001.html>
