[Qgis-developer] Grass v.to.points fails in processing toolbox
nagellette necipenesgengec at gmail.com
Mon Jul 21 03:59:25 PDT 2014
Hi All,
I had the following error when I try to calculate points to lines.
All other grass tools giving me similar error. I also tried older versions
(valmeira and dufour installed also.) got the error telling grass is not
installed properly. I installed 2.4.0 using osgeo installer, still having
the below error.
I am using win7 32bit, if that helps.
/Oooops! The following output layers could not be open
Output vector map where points will be written:
C:/Users/NGENGEC/Desktop/sample_2/roads_prj_pt.shp
The above files could not be opened, which probably indicates that they were
not correctly produced by the executed algorithm
Checking the log information might help you see why those layers were not
created as expected
This algorithm requires GRASS to be run. A test to check if GRASS is
correctly installed and configured in your system has been performed, with
the following result:
GRASS seems to be correctly installed and configured/
regards,
Necip.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Grass-v-to-points-fails-in-processing-toolbox-tp5152095.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
