[Qgis-developer] Grass v.to.points fails in processing toolbox
Victor Olaya volayaf at gmail.com
Mon Jul 21 04:03:57 PDT 2014
What does it say in the Processing log? Could you send it so we can check
it and figure out what is happening?
Thanks
2014-07-21 12:59 GMT+02:00 nagellette <necipenesgengec at gmail.com>:
> Hi All,
> I had the following error when I try to calculate points to lines.
> All other grass tools giving me similar error. I also tried older versions
> (valmeira and dufour installed also.) got the error telling grass is not
> installed properly. I installed 2.4.0 using osgeo installer, still having
> the below error.
> I am using win7 32bit, if that helps.
> /Oooops! The following output layers could not be open
> Output vector map where points will be written:
> C:/Users/NGENGEC/Desktop/sample_2/roads_prj_pt.shp
> The above files could not be opened, which probably indicates that they
> were
> not correctly produced by the executed algorithm
> Checking the log information might help you see why those layers were not
> created as expected
> This algorithm requires GRASS to be run. A test to check if GRASS is
> correctly installed and configured in your system has been performed, with
> the following result:
> GRASS seems to be correctly installed and configured/
> regards,
> Necip.
> http://osgeo-org.1560.x6.nabble.com/Grass-v-to-points-fails-in-processing-toolbox-tp5152095.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140721/bdfb6791/attachment.html>
