[Qgis-developer] compile error
Andreas Neumann a.neumann at carto.net
Wed Jul 23 07:57:46 PDT 2014
Jürgen or Nathan - can you please disable the sip parts for now, as
discussed - as currently I can't compile master on Ubuntu.
Maybe we can re-introduce it once the Debian/Ubuntu issues around
qscintilla and sip are resolved.
This would be much appreciated!
Thanks,
Andreas
Am 22.07.2014 14:18, schrieb Nathan Woodrow:
> Hey Jurgen,
> We can disable the sip parts for the code editors for now if it is
> causing issues.  They are really only light wrappers around some
> QScintilla code.
> - Nathan
> On Tue, Jul 22, 2014 at 10:06 PM, Jürgen E. <jef at norbit.de
> <mailto:jef at norbit.de>> wrote:
>     Hi Andreas,
>     On Tue, 22. Jul 2014 at 11:53:14 +0000, Andreas Neumann wrote:
>     > same problem here.
>     > qscimod4.sip is not available on my machine and I don't know which
>     > ubuntu package would contain this file.
>     That's a debian bug
>     (https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=755491)
>     The sip files are not currently packaged.
>     As a workaround I included them in QGIS [8f0b8987 & 7e815cad] - but
>     only the
>     latest version (in debian) - which could have worked for older ones
>     as well, if
>     Qscintillas API was stable enough.
>     Apparently it isn't.  The nightly builds failed with precise already
>     - saucy
>     and trust worked however, but that's as far as it got as of now.
>      I'll check
>     what else I can do, once I now which other distributions are affected.
>     Jürgen
>     Jürgen E. Fischer           norBIT GmbH             Tel.
>     +49-4931-918175-31
>     Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
>     +49-4931-918175-50
>     Software Engineer           D-26506 Norden
>     http://www.norbit.de
>     QGIS release manager (PSC)  Germany                    IRC: jef on
>     FreeNode
>     norBIT Gesellschaft fuer Unternehmensberatung und
>     Informationssysteme mbH
>     Rheinstrasse 13, 26506 Norden
>     GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
