[Qgis-developer] Error in LizMap printing
Andreas Neumann a.neumann at carto.net
Thu Jul 31 06:48:13 PDT 2014
Everyone is invited to make a pull-request to the documentation or edit
the QGIS server tutorial on the wiki.
Obviously - installing QGIS server is somewhat trickier than QGIS
desktop, because you have to deal with Apache, Apache rewriting,
potentially also password protection, etc - and you have to make sure
that all the paths to resources and Postgis connections from QGIS
desktop are still reachable by QGIS server.
The X-requirement is unfortunately necessary because of the way qt works
for PDF generation and for the integration of SVG symbols/patterns.
Andreas
Am 31.07.2014 13:38, schrieb Paolo Cavallini:
> On 2014-07-31 12:16, Paolo Cavallini wrote:
>> http://www.itopen.it/2014/03/13/qgis-server-setup-notes/
> I confirm it does solve the issue.
> I think we should set up a simpler solution however.
> Thanks, and sorry for the noise.
