[Qgis-developer] cannot run/ error after building from source
Matthias Kuhn
matthias.kuhn at gmx.ch
Sun Jun 1 00:31:48 PDT 2014
Hi Daniel,
You probably didn't set LD_LIBRARY_PATH:
http://hub.qgis.org/issues/5859
You may also run from the build directory:
./output/bin/qgis
Best,
Matthias
On 01.06.2014 09:17, Daniel Scholten wrote:
> After building from source (qgis 2.3 checked out yesterday), following
> http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc3
> I try to start qgis from comand line, but on comand line I get
> ./qgis: symbol lookup error: ./qgis: undefined symbol:
> _ZN17QgsLayerTreeGroup16staticMetaObjectE
> This happens with a local build/ installation, while there is another
> system wide installation of qgis. I use Linux Mint 13.
> Any suggestions what to do? Thanks
> Daniel
> Qgis-developer mailing list
