[Qgis-developer] error after building from source
Daniel Scholten
scholten at riseup.net
Sun Jun 1 00:42:57 PDT 2014
Thanks Matthias, removing the system installation and setting
LD_LIBRARY_PATH solved the issue. But now I have the already known problem:
During start of QGIS I get a Python error "Couldn't load plugin
'processing' [...]" and after a message "Unable to load GdalTools
plugin. The required "osgeo [python-gdal]" module is missing.". However,
QGIS starts and in the plugin manager with GdalTools everything seems to
be ok, whereas processing plugin is marked broken and the reinstall
button is disabled.
Any suggestions what to do? Daniel
I attach the full python error.
Couldn't load plugin 'processing' from ['/usr/local/share/qgis/python', '/home/user/.qgis2/python', '/home/user/.qgis2/python/plugins', '/usr/local/share/qgis/python/plugins', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL', '/usr/lib/python2.7/dist-packages/gst-0.10', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7', '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
File "/usr/local/share/qgis/python/qgis/utils.py", line 182, in loadPlugin
__import__(packageName)
File "/usr/local/share/qgis/python/qgis/utils.py", line 453, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/usr/local/share/qgis/python/plugins/processing/__init__.py", line 29, in
from processing.tools.general import *
File "/usr/local/share/qgis/python/plugins/processing/tools/general.py", line 29, in
from processing.core.Processing import Processing
File "/usr/local/share/qgis/python/plugins/processing/core/Processing.py", line 49, in
from processing.algs.qgis.QGISAlgorithmProvider import QGISAlgorithmProvider
File "/usr/local/share/qgis/python/plugins/processing/algs/qgis/QGISAlgorithmProvider.py", line 77, in
from RasterLayerStatistics import RasterLayerStatistics
File "/usr/local/share/qgis/python/plugins/processing/algs/qgis/RasterLayerStatistics.py", line 36, in
from processing.tools import raster
File "/usr/local/share/qgis/python/plugins/processing/tools/raster.py", line 29, in
from osgeo import gdal
ImportError: No module named osgeo
Python version:
2.7.3 (default, Feb 27 2014, 20:11:37)
[GCC 4.6.3]
QGIS version:
2.3.0-Master Master, 4670a16
Python path: ['/usr/local/share/qgis/python', u'/home/user/.qgis2/python', u'/home/user/.qgis2/python/plugins', '/usr/local/share/qgis/python/plugins', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL', '/usr/lib/python2.7/dist-packages/gst-0.10', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7', '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
