[Qgis-developer] Share some of my Processing Scripts
Giovanni Manghi giovanni.manghi at faunalia.pt
Sun Jun 1 16:27:21 PDT 2014
> - Contour : make contours around points at levels (based on the contour plugin)
> - Buffer contour : make and merge circular buffer around points at levels
> - Points at crossing / touching lines : make a point layer where lines cross or touch each other (2 scripts)
> - Fill holes : remove holes in polygons under a certain area
> - Remove parts : delete parts in multi polygons under a certain area
> - cut by field : cut one polygon layer by another when 2 polygons share a field value
very nice both sets of scripts! why not adding them into processing?
cheers!
-- G --
