[Qgis-developer] GSOC Weekly Report 2: Schematization Plug-in for QGIS
Nishith Maheshwari
nshthm at gmail.com
Sun Jun 1 20:46:56 PDT 2014
Hi all,
Sorry for the delay.
*Weekly Report 2*
*What was done this week?*
- There is exampleprovider
<https://github.com/qgis/QGIS/tree/master/python/plugins/processing/exampleprovider>
which
is available in the Processing plugin
<https://github.com/qgis/QGIS/tree/master/python/plugins/processing> as
an example plugin to add algorithms to the Processing framework. This will
be used as a base.
- Have added the functionality for simplification using
QgsTopologyPreservingSimplifier function in the above mentioned example
plugin. Code can be found at this link </>
- But this alone is incomplete/insufficient for simplification as there
is a need to do pre-processing otherwise the output won't be as desired.
*What is the plan for next week?*
- In the coming week I'll be tweaking with the models given in
processing toolbox and using the algorithms already in it will implement
proper pre-processing steps in the plug-in.
*Wiki page : *http://hub.qgis.org/wiki/quantum-gis/nishithm
*Code repository : *https://github.com/nishithm/schematization
Thanks and regards,
Nishith Maheshwari
Lab for Spatial Informatics
IIIT Hyderabad
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140602/7c67cb28/attachment.html>
