[Qgis-developer] Testing/Master renders 7times slower than 2.2
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Tue Jun 3 08:14:56 PDT 2014
Hi Anita -
I've just tried your project on my win8 pc with QGIS 2.3 32 bit and
compared it with my QGIS 2.0 set-up on the same pc:
Start-up times for the "annecy" project (QGIS already started with an
empty project):
  * QGIS 2.0: 6.7 sec. every time.
  * QGIS 2.3: 1. time 6.9 sec.; 2. time: 7.5 sec.; 3. time: 8.4 sec.
    .... 7. time: 11.9 sec. I've loaded an empty project between each
    iteration.
It takes between 0.6 -  0.9 sec. longer for each reload of the project.
If I restart QGIS and load the "annecy" project the load time falls to
6.9 sec. again.
The QGIS Code revision number is  ca6d4d9.
Regards
Bo Victor Thomsen
Aestas-GIS
Denmark
Den 03-06-2014 14:21, Anita Graser skrev:
> Hi Giovanni,
> On Tue, Jun 3, 2014 at 12:57 PM, Giovanni Manghi
> <giovanni.manghi at faunalia.pt> wrote:
>> On Mon, Jun 2, 2014 at 6:38 AM, Anita Graser <anitagraser at gmx.at> wrote:
>>> Hi Giovanni.
>>> I just counted until the map was done rendering: 3 versus approx 21 seconds.
>> What I see is the following:
>> on Linux (physical machine) your project opens really fast (~3
>> seconds) on qgis master
>> on Windows (virtual machine) the project opens in 7/8 seconds, on both
>> 2.2 and master (there is may be a little difference between the two,
>> but not as big as your are seeing).
> Thanks for your feedback. I'll check a second windows machine, maybe I
> just screwed up something on the Win8 machine to cause these huge
> differences.
> Maybe you could send me a screenshot of the rendering options you are using?
> Best wishes,
> Anita
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140603/92f6fac5/attachment-0001.html>
