[Qgis-developer] Testing/Master renders 7times slower than 2.2
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Tue Jun 3 14:23:19 PDT 2014
I've delved a little bit further into the matter:
Anita's original project is a 2.2 project. If you convert the project to
version 2.4 by simply saving it and then open the new version 2.4
project the time to open it is reduced to 6.0 sec. Every time.
So the delays is due to QGIS 2.3 opening a version 2.2 project.
Regards
Bo Victor Thomsen
Aestas-GIS
Denmark
Den 03-06-2014 17:14, Bo Victor Thomsen skrev:
> Hi Anita -
> I've just tried your project on my win8 pc with QGIS 2.3 32 bit and
> compared it with my QGIS 2.0 set-up on the same pc:
> Start-up times for the "annecy" project (QGIS already started with an
> empty project):
> * QGIS 2.0: 6.7 sec. every time.
> * QGIS 2.3: 1. time 6.9 sec.; 2. time: 7.5 sec.; 3. time: 8.4 sec.
> .... 7. time: 11.9 sec. I've loaded an empty project between each
> iteration.
> It takes between 0.6 - 0.9 sec. longer for each reload of the
> project. If I restart QGIS and load the "annecy" project the load time
> falls to 6.9 sec. again.
> The QGIS Code revision number is ca6d4d9.
> Regards
> Bo Victor Thomsen
> Aestas-GIS
> Denmark
> Den 03-06-2014 14:21, Anita Graser skrev:
>> Hi Giovanni,
>> On Tue, Jun 3, 2014 at 12:57 PM, Giovanni Manghi
>> <giovanni.manghi at faunalia.pt> wrote:
>>> On Mon, Jun 2, 2014 at 6:38 AM, Anita Graser<anitagraser at gmx.at> wrote:
>>>> Hi Giovanni.
>>>> I just counted until the map was done rendering: 3 versus approx 21 seconds.
>>> What I see is the following:
>>> on Linux (physical machine) your project opens really fast (~3
>>> seconds) on qgis master
>>> on Windows (virtual machine) the project opens in 7/8 seconds, on both
>>> 2.2 and master (there is may be a little difference between the two,
>>> but not as big as your are seeing).
>> Thanks for your feedback. I'll check a second windows machine, maybe I
>> just screwed up something on the Win8 machine to cause these huge
>> differences.
>> Maybe you could send me a screenshot of the rendering options you are using?
>> Best wishes,
>> Anita
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140603/c5e9ade5/attachment.html>
