[Qgis-developer] Legend refactoring branch merged
Martin Dobias
wonder.sk at gmail.com
Tue Jun 3 11:04:29 PDT 2014
Hi Tim
On Tue, Jun 3, 2014 at 7:14 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Ah on this topic I dont know if we mentioned it in Vienna when you were
> gathering requirements, but one thing I *often* get asked by users is why
> when adding new layers (multiple at once) QGIS does not add them in 'natural
> z-order' with polygons below then lines in the middle, then points above. Is
> this something you could do? I believe sorting should only apply to the
> added layers (so adding the sorted layer above the current layer rather than
> above the last layer of their geometry type). Though no doubt somebody will
> think just the opposite....:-)
Hmmm this feature should be actually quite easy to add. I'm just
wondering where to put layers without geometry (to the top?) and
raster layers (to the bottom?)
Regards
Martin
