[Qgis-developer] Incremental rendering of WMT-S tiles onto map canvas
Jeremy Palmer
JPalmer at linz.govt.nz
Wed Jun 4 02:01:26 PDT 2014
In QGIS 2.2 if you checked "Use render caching where possible to speed up redraws" in the rendering options WMT-S tiles were drawn immediately after download on the screen. Under QGIS master this no longer happens - with or without MTR enabled
Is it possible to get this feature back? It really improves usability for users and makes the application seem more responsive.
Cheers
Jeremy
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
