[Qgis-developer] Unknown attribute editor widget 'LineEdit'
Matthias Kuhn matthias.kuhn at gmx.ch
Wed Jun 4 03:01:55 PDT 2014
Hi Andreas,
Commit b98c2fec [1] should fix this.
I think it was merely a cosmetic issue.
I guess level is connected to severity and can be interpreted the way
you say, but no promise.
Matthias
[1]
https://github.com/qgis/QGIS/commit/b98c2fec1bbafbc312057504541cd52c07fa0a19
On Mit 04 Jun 2014 11:54:19 CEST, Andreas Neumann wrote:
> Hi Matthias,
> I don't experience any issues because of this. But there are a lot of
> such messages in the log windows and it looks like an error.
> It seems if I save it under a different project file (with master
> version) and reload it again it seems to be fine. So I would assume
> this message only comes up when opening old project files.
> QGIS would then convert it to the new widget type, correct?
> BTW: what does the "level" column mean in the log message panel? The
> higher the more severe?
> Andreas
> Am 2014-06-04 11:07, schrieb Matthias Kuhn:
>> Hi Andreas,
>> Is it just the message or did you experience any problems attached to
>> it?
>> Please open an issue, I'll have a look.
>> Matthias
>> On Mit 04 Jun 2014 10:54:48 CEST, Andreas Neumann wrote:
>>> Hi,
>>> In the log messages I get a lot of messages like
>>> "Unknown attribute editor widget 'LineEdit'"
>>> I assume this is a side effect of the widget redesign?
>>> Do others have the same issue? Should I file a bug or is this already
>>> known?
>>> Andreas
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
