[Qgis-developer] Unknown attribute editor widget 'LineEdit'
Andreas Neumann a.neumann at carto.net
Wed Jun 4 02:54:19 PDT 2014
Hi Matthias,
I don't experience any issues because of this. But there are a lot of
such messages in the log windows and it looks like an error.
It seems if I save it under a different project file (with master
version) and reload it again it seems to be fine. So I would assume this
message only comes up when opening old project files.
QGIS would then convert it to the new widget type, correct?
BTW: what does the "level" column mean in the log message panel? The
higher the more severe?
Andreas
Am 2014-06-04 11:07, schrieb Matthias Kuhn:
> Hi Andreas,
> Is it just the message or did you experience any problems attached to
> it?
> Please open an issue, I'll have a look.
> Matthias
> On Mit 04 Jun 2014 10:54:48 CEST, Andreas Neumann wrote:
>> Hi,
>> In the log messages I get a lot of messages like
>> "Unknown attribute editor widget 'LineEdit'"
>> I assume this is a side effect of the widget redesign?
>> Do others have the same issue? Should I file a bug or is this already
>> known?
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
