[Qgis-developer] spatial joins and select by location should not consider polygons than only touch
G. Allegri giohappy at gmail.com
Thu Jun 5 03:58:49 PDT 2014
NP, I will pull it after the release of 2.4. No hurry ;)
In the meanwhile I will give a look to the bug-fixing activity, in case I
find some time to contribute.
giovanni
2014-06-05 11:52 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
> Am 05.06.2014 06:46, schrieb G. Allegri:
> > Hi Andreas,
> > I'm doing it :)
> ah good!
> > As you can see I've added the checkox options to have fine control on
> > spatial relations. I could add the threashold value as well.
> > I know we are in feature freeze, I'm doing it for the next 2.5/2.6.
> Should
> > I wait for 2.4 release before submitting pull requests with new features?
> Well - if you do it now there is a risk of conflicts if you merge it
> after the lift of the feature freeze. Typically, after the feature
> freeze a lot of new features that did not make it into 2.4 are coming in
> and there is a risk of conflicts. But in your particular case I don't
> think there will be conflicts in this part of the code.
> The other thing is that we should now be concentrating on testing and
> bug-fixing ;-)
> Thanks for you work anyway - no matter when you do it,
> Andreas
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140605/b620de0d/attachment-0001.html>
