[Qgis-developer] spatial joins and select by location should not consider polygons than only touch
Andreas Neumann a.neumann at carto.net
Thu Jun 5 02:52:15 PDT 2014
Am 05.06.2014 06:46, schrieb G. Allegri:
> Hi Andreas,
> I'm doing it :)
ah good!
> As you can see I've added the checkox options to have fine control on
> spatial relations. I could add the threashold value as well.
> I know we are in feature freeze, I'm doing it for the next 2.5/2.6. Should
> I wait for 2.4 release before submitting pull requests with new features?
Well - if you do it now there is a risk of conflicts if you merge it
after the lift of the feature freeze. Typically, after the feature
freeze a lot of new features that did not make it into 2.4 are coming in
and there is a risk of conflicts. But in your particular case I don't
think there will be conflicts in this part of the code.
The other thing is that we should now be concentrating on testing and
bug-fixing ;-)
Thanks for you work anyway - no matter when you do it,
Andreas
