[Qgis-developer] Legend refactoring branch merged
Tim Sutton lists at linfiniti.com
Thu Jun 5 21:03:31 PDT 2014
Hi
On Fri, Jun 6, 2014 at 10:55 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi Tim
> On Fri, Jun 6, 2014 at 10:50 AM, Tim Sutton <lists at linfiniti.com> wrote:
> > Hi Martin
> > One other glitch I have found is that loading a QML style file in the
> > properties dialog sometimes (always?) does not refresh the legend when
> you
> > close the dialog. Saving the project, closing and reopening it does
> cause it
> > to refresh.
> How old is your git checkout? I have probably fixed that issue
> yesterday - #10469 had very similar symptoms as you describe.
Ah ok I built yesterdam morning early. Compiling now and will come back to
you if I still see the issue. Thanks!
Tim
> Regards
> Martin
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140606/05fe8489/attachment.html>
