[Qgis-developer] Legend refactoring branch merged
Tim Sutton
lists at linfiniti.com
Fri Jun 6 02:41:29 PDT 2014
One more issue I have found is that the commit below introduces a crash if
you add layers from different crs's.
timlinux at channel:~/dev/cpp/QGIS$ git bisect good
a04ebf9eb012bb7b6f05300e5d3e676e4603553e is the first bad commit
commit a04ebf9eb012bb7b6f05300e5d3e676e4603553e
Author: Martin Dobias <wonder.sk at gmail.com>
Date: Thu Jun 5 20:23:34 2014 +0700
Reintroduce datum transforms (were disabled during transition to MTR)
:040000 040000 7c6366ef03b946eab2c6640f455f9f34e32f6210
51562407787ad5eb31f68bc7c4bfb269e4b2bf30 M python
:040000 040000 ada46001fe3dc45e1aaafcbdf0158cc86ac33522
c9b65fb2c3dc0a7516ba68b2bbf4a90193f38a78 M src
Sample data here:
http://data.inasafe.org/ScenarioDataPackages/BimaTsunami_TestData.zip
If you add the raster bil file at the same time the vector layers QGIS will
crash.
Regards
Tim
On Fri, Jun 6, 2014 at 11:03 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Fri, Jun 6, 2014 at 10:55 AM, Martin Dobias <wonder.sk at gmail.com>
> wrote:
>> Hi Tim
>> On Fri, Jun 6, 2014 at 10:50 AM, Tim Sutton <lists at linfiniti.com> wrote:
>> > Hi Martin
>> > One other glitch I have found is that loading a QML style file in the
>> > properties dialog sometimes (always?) does not refresh the legend when
>> you
>> > close the dialog. Saving the project, closing and reopening it does
>> cause it
>> > to refresh.
>> How old is your git checkout? I have probably fixed that issue
>> yesterday - #10469 had very similar symptoms as you describe.
> Ah ok I built yesterdam morning early. Compiling now and will come back to
> you if I still see the issue. Thanks!
> Tim
>> Regards
>> Martin
> Tim Sutton - QGIS Project Steering Committee Member
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140606/ebbf3c41/attachment.html>
