[Qgis-developer] Legend refactoring branch merged
Martin Dobias
wonder.sk at gmail.com
Fri Jun 6 03:00:42 PDT 2014
Hi Tim,
this one was fixed this morning in PR #1429 :-)
Regards
Martin
On Fri, Jun 6, 2014 at 4:41 PM, Tim Sutton <lists at linfiniti.com> wrote:
> One more issue I have found is that the commit below introduces a crash if
> you add layers from different crs's.
> timlinux at channel:~/dev/cpp/QGIS$ git bisect good
> a04ebf9eb012bb7b6f05300e5d3e676e4603553e is the first bad commit
> commit a04ebf9eb012bb7b6f05300e5d3e676e4603553e
> Author: Martin Dobias <wonder.sk at gmail.com>
> Date: Thu Jun 5 20:23:34 2014 +0700
> Reintroduce datum transforms (were disabled during transition to MTR)
> :040000 040000 7c6366ef03b946eab2c6640f455f9f34e32f6210
> 51562407787ad5eb31f68bc7c4bfb269e4b2bf30 M python
> :040000 040000 ada46001fe3dc45e1aaafcbdf0158cc86ac33522
> c9b65fb2c3dc0a7516ba68b2bbf4a90193f38a78 M src
> Sample data here:
> http://data.inasafe.org/ScenarioDataPackages/BimaTsunami_TestData.zip
> If you add the raster bil file at the same time the vector layers QGIS will
> crash.
> Regards
> Tim
> On Fri, Jun 6, 2014 at 11:03 AM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> On Fri, Jun 6, 2014 at 10:55 AM, Martin Dobias <wonder.sk at gmail.com>
>> wrote:
>>> Hi Tim
>>> On Fri, Jun 6, 2014 at 10:50 AM, Tim Sutton <lists at linfiniti.com> wrote:
>>> > Hi Martin
>>> > One other glitch I have found is that loading a QML style file in the
>>> > properties dialog sometimes (always?) does not refresh the legend when
>>> > you
>>> > close the dialog. Saving the project, closing and reopening it does
>>> > cause it
>>> > to refresh.
>>> How old is your git checkout? I have probably fixed that issue
>>> yesterday - #10469 had very similar symptoms as you describe.
>> Ah ok I built yesterdam morning early. Compiling now and will come back to
>> you if I still see the issue. Thanks!
>> Tim
>>> Regards
>>> Martin
>> Tim Sutton - QGIS Project Steering Committee Member
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Irc: timlinux on #qgis at freenode.net
