[Qgis-developer] Legend refactoring branch merged
Tim Sutton lists at linfiniti.com
Fri Jun 6 06:11:23 PDT 2014
Hi
On Fri, Jun 6, 2014 at 5:00 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi Tim,
> this one was fixed this morning in PR #1429 :-)
Doh! I am always one step behind :-)
Thanks!
Regards
Tim
> Regards
> Martin
> On Fri, Jun 6, 2014 at 4:41 PM, Tim Sutton <lists at linfiniti.com> wrote:
> > One more issue I have found is that the commit below introduces a crash
> if
> > you add layers from different crs's.
> > timlinux at channel:~/dev/cpp/QGIS$ git bisect good
> > a04ebf9eb012bb7b6f05300e5d3e676e4603553e is the first bad commit
> > commit a04ebf9eb012bb7b6f05300e5d3e676e4603553e
> > Author: Martin Dobias <wonder.sk at gmail.com>
> > Date:   Thu Jun 5 20:23:34 2014 +0700
> >     Reintroduce datum transforms (were disabled during transition to MTR)
> > :040000 040000 7c6366ef03b946eab2c6640f455f9f34e32f6210
> > 51562407787ad5eb31f68bc7c4bfb269e4b2bf30 M python
> > :040000 040000 ada46001fe3dc45e1aaafcbdf0158cc86ac33522
> > c9b65fb2c3dc0a7516ba68b2bbf4a90193f38a78 M src
> > Sample data here:
> > http://data.inasafe.org/ScenarioDataPackages/BimaTsunami_TestData.zip
> > If you add the raster bil file at the same time the vector layers QGIS
> will
> > crash.
> > Regards
> > Tim
> > On Fri, Jun 6, 2014 at 11:03 AM, Tim Sutton <lists at linfiniti.com> wrote:
> >> Hi
> >> On Fri, Jun 6, 2014 at 10:55 AM, Martin Dobias <wonder.sk at gmail.com>
> >> wrote:
> >>> Hi Tim
> >>> On Fri, Jun 6, 2014 at 10:50 AM, Tim Sutton <lists at linfiniti.com>
> wrote:
> >>> > Hi Martin
> >>> > One other glitch I have found is that loading a QML style file in the
> >>> > properties dialog sometimes (always?) does not refresh the legend
> when
> >>> > you
> >>> > close the dialog. Saving the project, closing and reopening it does
> >>> > cause it
> >>> > to refresh.
> >>> How old is your git checkout? I have probably fixed that issue
> >>> yesterday - #10469 had very similar symptoms as you describe.
> >> Ah ok I built yesterdam morning early. Compiling now and will come back
> to
> >> you if I still see the issue. Thanks!
> >> Tim
> >>> Regards
> >>> Martin
> >> Tim Sutton - QGIS Project Steering Committee Member
> >> Please do not email me off-list with technical
> >> support questions. Using the lists will gain
> >> more exposure for your issues and the knowledge
> >> surrounding your issue will be shared with all.
> >> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140606/157abffd/attachment-0001.html>
