[Qgis-developer] Legend refactoring branch merged
Tim Sutton
lists at linfiniti.com
Fri Jun 6 07:25:36 PDT 2014
Hi
On Fri, Jun 6, 2014 at 8:11 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Fri, Jun 6, 2014 at 5:00 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
>> Hi Tim,
>> this one was fixed this morning in PR #1429 :-)
> Doh! I am always one step behind :-)
Ok that works fine for me now. And you fixed the double click on the layer
thing which was driving me nuts when it was trying to edit the name all the
time.
I think I have actually run out of issues and the legend is working great
for me - thanks for all your hard work!
Regards
Tim
> Thanks!
> Regards
> Tim
>> Regards
>> Martin
>> On Fri, Jun 6, 2014 at 4:41 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> > One more issue I have found is that the commit below introduces a crash
>> if
>> > you add layers from different crs's.
>> > timlinux at channel:~/dev/cpp/QGIS$ git bisect good
>> > a04ebf9eb012bb7b6f05300e5d3e676e4603553e is the first bad commit
>> > commit a04ebf9eb012bb7b6f05300e5d3e676e4603553e
>> > Author: Martin Dobias <wonder.sk at gmail.com>
>> > Date: Thu Jun 5 20:23:34 2014 +0700
>> > Reintroduce datum transforms (were disabled during transition to
>> MTR)
>> > :040000 040000 7c6366ef03b946eab2c6640f455f9f34e32f6210
>> > 51562407787ad5eb31f68bc7c4bfb269e4b2bf30 M python
>> > :040000 040000 ada46001fe3dc45e1aaafcbdf0158cc86ac33522
>> > c9b65fb2c3dc0a7516ba68b2bbf4a90193f38a78 M src
>> > Sample data here:
>> > http://data.inasafe.org/ScenarioDataPackages/BimaTsunami_TestData.zip
>> > If you add the raster bil file at the same time the vector layers QGIS
>> will
>> > crash.
>> > Regards
>> > Tim
>> > On Fri, Jun 6, 2014 at 11:03 AM, Tim Sutton <lists at linfiniti.com>
>> wrote:
>> >> Hi
>> >> On Fri, Jun 6, 2014 at 10:55 AM, Martin Dobias <wonder.sk at gmail.com>
>> >> wrote:
>> >>> Hi Tim
>> >>> On Fri, Jun 6, 2014 at 10:50 AM, Tim Sutton <lists at linfiniti.com>
>> wrote:
>> >>> > Hi Martin
>> >>> > One other glitch I have found is that loading a QML style file in
>> the
>> >>> > properties dialog sometimes (always?) does not refresh the legend
>> when
>> >>> > you
>> >>> > close the dialog. Saving the project, closing and reopening it does
>> >>> > cause it
>> >>> > to refresh.
>> >>> How old is your git checkout? I have probably fixed that issue
>> >>> yesterday - #10469 had very similar symptoms as you describe.
>> >> Ah ok I built yesterdam morning early. Compiling now and will come
>> back to
>> >> you if I still see the issue. Thanks!
>> >> Tim
>> >>> Regards
>> >>> Martin
>> >> Tim Sutton - QGIS Project Steering Committee Member
>> >> Please do not email me off-list with technical
>> >> support questions. Using the lists will gain
>> >> more exposure for your issues and the knowledge
>> >> surrounding your issue will be shared with all.
>> >> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140606/28d3fe15/attachment-0001.html>
