[Qgis-developer] Incoeherent behavior in selecting layesr in add Postgis and spatialite Layer Dialogs
Alexandre Neto
senhor.neto at gmail.com
Mon Jun 9 03:26:43 PDT 2014
While translating the Help from add Postgis Layer, I realized that the
layer selection behavior is not according.
The help says that one needs to hold Ctrl-key to be able to select\add more
than one table, yet in the current behavior every selection is kept when
another layer is clicked.
On the other hand, Add Spatialite Layer Dialog, the Ctrl-key is needed to
select more than one layer.
This happens in both 2.2 and master
Should I open a ticket?
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140609/4acb7ff1/attachment.html>
