[Qgis-developer] Trouble compiling QGIS on Ubuntu Server
Andreas Neumann
a.neumann at carto.net
Tue Jun 10 01:59:32 PDT 2014
With the self-compiled libspatialite (4.1.1) I am now able to compile
QGIS server. It does not work with the internal spatialite library
provided by QGIS and it also fails with the version provided by Ubuntu
14.04 ;-(
Now I am running into the next issue that Apache does not find my
Postgis-Service definitions. Maybe the Apache 2.4 environment variables
have a different setup than in previous Apache / Ubuntu Server versions.
Thanks for the hint - eventually I will be getting there,
Andreas
Am 2014-06-10 09:53, schrieb Andrea Peri:
> I work on Debina. stable.
> I download the spatialite from home site and compile from source.
> is surely easy and no problem at all.
> I download and use the SL 4.2.0 RC1, but as reported in another thread
> of this ML.
> There a little bug that ask to resolve manually.
> Add a define to spatialite source.
> If you use the SL 4.1.1 all go without no errors.
> And GQIS-server work very well.
> regards,
> Andrea.
> 2014-06-10 9:45 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> I am trying to compile QGIS server on a new Ubuntu 14.04 server.
>> I have trouble around spatialite and ‘gaiaVectorLayerPtr’.
>> The errors I get are as follows:
>> In file included from
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:31:0:
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.h:409:43:
>> error: ‘gaiaVectorLayerPtr’ has not been declared
>> bool checkLayerTypeAbstractInterface( gaiaVectorLayerPtr
>> lyr );
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.h:410:47:
>> bool getGeometryDetailsAbstractInterface(
>> gaiaVectorLayerPtr lyr );
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.h:411:44:
>> bool getTableSummaryAbstractInterface( gaiaVectorLayerPtr
>> lyr );
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.h:412:39:
>> void loadFieldsAbstractInterface( gaiaVectorLayerPtr lyr );
>> In constructor ‘QgsSpatiaLiteProvider::QgsSpatiaLiteProvider(const
>> QString&)’:
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:448:3:
>> error: ‘gaiaVectorLayersListPtr’ was not declared in this scope
>> gaiaVectorLayersListPtr list = NULL;
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:448:27:
>> error: expected ‘;’ before ‘list’
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:449:3:
>> error: ‘gaiaVectorLayerPtr’ was not declared in this scope
>> gaiaVectorLayerPtr lyr = NULL;
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:449:22:
>> error: expected ‘;’ before ‘lyr’
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:460:5:
>> error: ‘list’ was not declared in this scope
>> list = gaiaGetVectorLayersList( handle->handle(),
>> note: suggested alternative:
>> In file included from /usr/include/c++/4.8/list:63:0,
>> from /usr/include/qt4/QtCore/qlist.h:51,
>> from
>> /usr/include/qt4/QtCore/qobject.h:50,
>> from
>> /usr/include/qt4/QtCore/qiodevice.h:46,
>> from
>> /usr/include/qt4/QtCore/qdatastream.h:46,
>> from
>> /usr/include/qt4/QtCore/qmetatype.h:49,
>> from /usr/include/qt4/QtCore/QMetaType:1,
>> from
>> /root/dev/QGIS/src/providers/spatialite/../../core/qgis.h:24,
>> from
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:17:
>> /usr/include/c++/4.8/bits/stl_list.h:438:11: note:
>> ‘std::list’
>> class list : protected _List_base<_Tp, _Alloc>
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:463:37:
>> error: ‘GAIA_VECTORS_LIST_OPTIMISTIC’ was not declared in this
>> scope
>> GAIA_VECTORS_LIST_OPTIMISTIC );
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:463:66:
>> error: ‘gaiaGetVectorLayersList’ was not declared in this scope
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:465:7:
>> error: ‘lyr’ was not declared in this scope
>> lyr = list->First;
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:466:10:
>> if ( lyr == NULL )
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:508:8:
>> if ( lyr != NULL )
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:518:33:
>> gaiaFreeVectorLayersList( list );
>> from
>> from
>> from
>> from
>> from
>> from
>> ‘std::list’
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:518:38:
>> error: ‘gaiaFreeVectorLayersList’ was not declared in this scope
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:527:33:
>> from
>> from
>> from
>> from
>> from
>> from
>> ‘std::list’
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:527:38:
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:532:31:
>> from
>> from
>> from
>> from
>> from
>> from
>> ‘std::list’
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:532:36:
>> At global scope:
> /root/dev/QGIS/src/providers/spatialite/qgsspatialiteprovider.cpp:592:58:
>> error: variable or field ‘loadFieldsAbstractInterface’ declared
>> void
>> void QgsSpatiaLiteProvider::loadFieldsAbstractInterface(
>> make[2]: ***
> [src/providers/spatialite/CMakeFiles/spatialiteprovider.dir/qgsspatialiteprovider.cpp.o]
>> Error 1
>> make[1]: ***
>> [src/providers/spatialite/CMakeFiles/spatialiteprovider.dir/all]
>> Error 2
>> make[1]: *** Waiting for unfinished jobs....
>> I set the option to use the internal spatialite in the cmake
>> options. Do you have any idea how I may be able to fix this compile
>> problem?
>> Thanks,
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
> Andrea Peri
> qwerty àèìòù
> Links:
> [1] http://lists.osgeo.org/mailman/listinfo/qgis-developer
