[Qgis-developer] Trouble compiling QGIS on Ubuntu Server
Jürgen E. Fischer
jef at norbit.de
Tue Jun 10 02:26:12 PDT 2014
Hi Andreas,
On Tue, 10. Jun 2014 at 10:59:32 +0200, Andreas Neumann wrote:
> With the self-compiled libspatialite (4.1.1) I am now able to compile
> QGIS server. It does not work with the internal spatialite library
> provided by QGIS and it also fails with the version provided by Ubuntu
> 14.04 ;-(
Hm, the nightly builds for trusty apparently work fine. Did you already try
those? You could also try to build packages - as that comes with the
configuration options you need.
I guess we can remove the internal copy of spatialite...
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS PSC member (RM) Germany IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
