[Qgis-developer] [Qgis-user] Opinion on an idea for plugin - Print composer guide manager
Nyall Dawson
nyall.dawson at gmail.com
Wed Jun 11 04:24:49 PDT 2014
Hi Alexandre,
I agree that this would be a really useful feature - it's been on my
(lengthy!) to-do list for a while now. However, I think ideally this
should be implemented directly within QGIS, rather than as plug in.
I'm happy to work with you on this if you'd like guidance.
Nyall
On 11 June 2014 21:20, Alexandre Neto <senhor.neto at gmail.com> wrote:
> I have some difficulty in using print composers guides, not being able to
> precisely set their position. Normally I zoom in the map to a point that it
> really does not matter if it's the value is 10,0001 or 10,0002. But it feels
> weird doing it.
> My idea would be to create a plugin that would add a panel to print
> composer, listing all guides positions (along with the page number and
> vertical/horizontal reference).
> If needed, one could then precisely set each guide, add new guides, or
> remove existing ones.
> What do you thing? Would it be useful?
> Can anyone point me to API parts that I would need to check to complete this
> task?
> Thanks,
> Alexandre Neto
> Qgis-user mailing list
