[Qgis-developer] [Qgis-user] Opinion on an idea for plugin - Print composer guide manager
Andreas Neumann
a.neumann at carto.net
Wed Jun 11 05:30:02 PDT 2014
I agree - this should go into core in version 2.6 - guidelines that
behave similar to known drawing apps like Inkscape/Illustrator and a
guideline manager that allows to create, change and delete guidelines
with exact values.
Andreas
Am 2014-06-11 13:24, schrieb Nyall Dawson:
> Hi Alexandre,
> I agree that this would be a really useful feature - it's been on my
> (lengthy!) to-do list for a while now. However, I think ideally this
> should be implemented directly within QGIS, rather than as plug in.
> I'm happy to work with you on this if you'd like guidance.
> Nyall
> On 11 June 2014 21:20, Alexandre Neto <senhor.neto at gmail.com> wrote:
>> I have some difficulty in using print composers guides, not being able
>> to
>> precisely set their position. Normally I zoom in the map to a point
>> that it
>> really does not matter if it's the value is 10,0001 or 10,0002. But it
>> feels
>> weird doing it.
>> My idea would be to create a plugin that would add a panel to print
>> composer, listing all guides positions (along with the page number and
>> vertical/horizontal reference).
>> If needed, one could then precisely set each guide, add new guides, or
>> remove existing ones.
>> What do you thing? Would it be useful?
>> Can anyone point me to API parts that I would need to check to
>> complete this
>> task?
>> Thanks,
>> Alexandre Neto
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-developer mailing list
