[Qgis-developer] Split lines at intersection
Rouzaud Denis
denis.rouzaud at gmail.com
Wed Jun 11 06:05:38 PDT 2014
splitLinearGeometry is private, you won’t have access to it.
You shall use splitGeometry which is public
http://qgis.org/api/classQgsGeometry.html#a4c03fb2b37ce94bcf2295ed7896f665b
Cheers,
Denis
On 11 Jun 2014, at 12:42, mattwalsh <matthew.walsh at thinkwhere.com> wrote:
> Hello,
> Using pyqgis I would like to split a line feature where it intersects with
> another line. I have tried using the splitLinearGeometry function with no
> success.
> new_f = geom_feat.splitLinearGeometry([geom_feat_sp])
> AttributeError: 'QgsGeometry' object has no attribute 'splitLinearGeometry'
> My end goal is to split a number of selected line features against each
> other so that all the selected lines are split at all intersections.
> Could anyone point me in the right direction?
> thanks
> Matt
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Split-lines-at-intersection-tp5145241.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140611/188da5f8/attachment.html>
