[Qgis-developer] Question on inverted polygon renderer
Régis Haubourg
regis.haubourg at eau-adour-garonne.fr
Tue Jun 17 00:32:17 PDT 2014
Hi Bernard,
plugin is coming this week I think.
Bernhard Ströbl wrote
> Thinking about QGIS server: Would there be a chance to use what you
> describe to keep labels staying away from the edge of the requested map?
> Bernhard
current implementation adds a In_mask(srid) expression, that can be used
anywhere in style or labeling settings. If QGIs server fill current mask
geometry with a bbox, slightly smaller than true extent, you will avoid
drawing labels to close from the edges. I'm not sure this is the best design
option, it sounds more like a hack to me.
I will let Hugo explain detailed implementation.
Cheers
Régis
View this message in context: http://osgeo-org.1560.x6.nabble.com/Question-on-inverted-polygon-renderer-tp5146099p5146226.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
